Sailfree
I thought antifoul was self eroding and you just power washed it and scoured it with a green scourer and overcoat with extra coat of antifoul each year.
Last year I had small areas breaking off and I sanded down these areas. I then also had some other apparently sound areas peel off when overcoating with new antifoul. Talking about say on average 25mm round patches.
I think its adhesion problems possibly due to not scouring original surface enough or possibly not properly mixing Antifoul thoroughly.
This year I have started by using a carbide scraper on any loose areas and then sanding down using a Metabo 150mm Dual Action sander until I get a tapered edge. Finding some areas the layer doesn't so much as grind off but chips off again leaving an edge. On underside its just thin layers but towards side I am surprised by the total thickness.
Usually get through some 5ltrs of International Micron Extra on a 43' boat.
Can you put antifoul on too thick?
Can the layers build up too much?
Do you just pressure wash and overcoat or do you scour surface or even rub the surface down a bit?
