nimbusgb
Which Bahco pull scraper did anyone use, and which size blade?
I used a Bahco 650 2" Ergo Paint Scraper. I used 2 blades ( you can rotate the blades once to get a new edge ) the blades are 50mm wide and tungsten carbide I think, not worth sharpening unless you can guarantee a perfectly flat finish if you are removing paint or antifoul.
It has been suggested to round off the ends - say the last 2 or 3 mm of the blade to prevent gouging when ( not if ) you get the occasional stroke wrong. I didn't do this and had perhaps 6 gouges ranging from a couple of inches to one about a foot long.
Boat was a very beamy Oceanis 390, perhaps 34' lwl and it took me a day and a half to strip back about 10 years of antifoul right down to the gelcoat.
Best way short of blasting to get a/f off!
I subsequently grit blasted the hull and epoxy sheathed and coated it but if I had to remove a/f again it would be with that scraper.
