waterline
Can anyone please offer me some practical help about Antifouling and Epoxy coatings etc.
I bought a new 20' trailer sailer last May (Jeanneau SUN 2000) and need some advice about antifouling the hull. When I first had the boat delivered to Windermere I considered antifouling the underside and even epoxy coating, but after contacting a main Jeanneau dealer on the south coast I was advised to try the first season without any antifouling to see how bad the hull actually gets. I was also advised that epoxy coating the underside is not always necessary with new boats as modern production methods have resulted in more stable gelcoat etc.
The boat will be kept on fresh water only from April to end of October and when the boat was brought out of the water a month ago, the hull was covered in a geen slime that was fairly easy to wash off with boat cleaner. Because the boat has a lifting keel, it sits very low on the trailer which makes it hard to clean off the main underside area, and I am now beginning to wonder if I should have applied antifouling to keep the hull easier to keep clean, or even not clean it at all in the areas I can't get at with a brush.
Because of scare stories I have read about protecting fibreglass hulls, I am also beginning to wonder if I should have coated the hull with epoxy to give it more protection but am concsious of the difficulties that can occur when applying epoxy coatings, like controlling the temperature and humidity etc not to mention the high cost of paying a yard to do the job using a lifting cradle to gain access to the underside and also Winter may not be the best time to do this job. I have also been told about a product called VC Tar? that can be applied instead of Epoxy, and then antifouled on top. Can anyone shed some light on this method, and would I need to lightly sand the hull before applying this product?
If I go ahead and antifoul the underside, would I be correct in thinking that I would need to completely clean off any slime residue, clean with acetone (to get rid of any release agent and oil deposits from the lake), and lightly sand with wet & dry paper used dry (not sure which grade to use?)
Any advice would be most welcome to a novice sailer, even help with choosing the correct Antifouling (green colour) for fresh water that will last a couple of seasons would help me
