Novachris
Hi.i have these loops on both my toilet pipes,Jabsco toilet..the out let one leaks and hisses when i pump out,how can i stop this please?do i turn the little knob to close it? i dont have a holding tank btw.
Have a read through this thread - you can buy the little rubber 'duck bill' rubbers - and this will sort your leak.Hi.i have these loops on both my toilet pipes,Jabsco toilet..the out let one leaks and hisses when i pump out,how can i stop this please?do i turn the little knob to close it? i dont have a holding tank btw.
http://www.ybw.com/forums/showthread.php?328197-Vented-loops-Am-I-mad
Ash
They are designed to let air in so as to break the siphon so, after pumping, a little hissing is acceptable. There shouldnt be any hissing when actualy pumping as this implies that the air is being forced out the wrong way. If you also have leaks then thats further proof that the duck bill needs to be replaced. As stated by VicS, could suggest a high back pressure in the waste pipe caused by obstruction in the waste pipe or scaled up pipework.
Maybe my numpty - I didn't recheck - I bought in Augut 2012 - from Cleghorn Waring - 1 xthanks....cant seem to find them in the link...numptie moment![]()
when i serviced the blakes i might have put the handle of the seacock back on 180deg out as it seems open position is now closed position,is this even possible?
Never seen a ''toilet'' on a boat. Perhaps you mean Heads ?
No..the toilet is in the head of the boat...so toilet i meant..but thanks for the input, do you know how to fix my toilet anti syphon, out of interest?
