Nostrodamus
If it can save 9000 then 100 is not so bad to replace it what ever colour it is.
I am wondering if the annual flushing before winter lay up of the seawater system with fresh water and then anti rust/freeze can actually clean those valves. I did clean it in my boat (even though it looked OK) but I was concerned if that little spring can be damaged by opening/closing every year.
What do you think?
The other one with the yellow hat comes with the Onan generator. It is a little non return valve which I removed from the vertical tube. I could not see the flap valve but washed it out with fresh water and blew is through. The yellow cap allows air up and into the NRV as it is not a sealed fit
