sequena1
I read (several times) with interest the contributions regarding anti-syphon loops. I wonder if anyone has any thoughts on this setup. I'm installing a Lavac which will be connected through a manual pump directly to a large Tek-tanks holding tank below the water-line. There will be no option to bypass it. The latter will be emptied, again with a manual pump and an above the water-line loop to the underwater discharge skin-fitting. I know I need a vent in the water inlet loop but do I need vents in either the pipe exiting the loo or the discharge pipe. Doesn't the large (1 1/2 inch) vent pipe from the holding tank emerging way above the waterline act as an anti-syphon for both sides of the holding tank?
