rogerthebodger
I believe the USCG requirement may only apply to gasoline fuel systems
The introduction states that it only applied to gasolene and what thy also call SI (spark ignition) engines
Yes I saw that but only after I,d made the comment earlierThe introduction states that it only applied to gasolene and what thy also call SI (spark ignition) engines
The vac gauge seems like a good idea, my Racor is in a difficult to access place. Removing the unit doesn’t fill me with joy, just hoping my problem is the spin on filter on the engine being gunked up.Jamie - the first time I dismantled the Racor with an engineer he was very keen on stripping down the Racor and suggested the ball should be cleaned. Perhaps he was right. It is difficult to find clarrity. It is very straightforward once the Racor is on the bench - not a job to do in situ.
I have a vac gauge on the top of the Racor which has proved very useful. It is an instant indication of whether the vac is out of parameters. You probably know the lift pump should be on the engine side, so if the vac. rises it seems to me there are relatively few possible causes. The obvious is the filter has come to the end of its life (which I have had, and is an instant solution) or something along the lines of the problem possibly we both have. I can understand if the ball sticks partinally closed it would result in exactly this issue, I just cant yet see that it is likely it would.
I wish my problem was instantly repeatable for obvious reasons. Strangely I hope when I run the engine next the vac will instantly rise, so when I strip and clean the Racor and it goes away I will know the problem is cured!
Having stripped down several Racors, I can't see how the Racor ball could stick in the closed position as it's only gravity that keeps it closed. It could certainly stick in the open position and fail to close and, indeed, many Racors are stuck open because they have been wrongly reassembled but all this means is that fuel tends to drain back to the tank when the engine is stopped. depending upon the relative heights.Jamie - the first time I dismantled the Racor with an engineer he was very keen on stripping down the Racor and suggested the ball should be cleaned. Perhaps he was right. It is difficult to find clarrity. It is very straightforward once the Racor is on the bench - not a job to do in situ.
Sticking partially open is very common with the Racors. Both mine were sticking open because the valve seat was installed upside down. However, sticking open will not affect the running of the engine at all so that cannot be your problem.It is even more unlikely it would stick partially open it seems to be - I can understand even jammed closed, but not the partial bit, as I get enough fuel through mine to run at 1,500 rpm.
As I said above, an incorrectly installed valve seat in the Racor allows fuel to drain back to the tank when the engine is stopped but that is all.For those who might be interested, I disconnected the fuel pipe from the tank which proved easier than I thought. I sucked out the pipe with an oil remover and blew through some air. There was no obvious blockage. it was correct there was no anti siphon valve on the tank, just a right angle connector and on / off tap. Blew through the tap and no issue. The pickup was interesting. I expected a removable pickup but it was a wide aluminium tube welded in place and of original manufacture. I blew through this as well. No signs of blockage either. Engine ran perfectly on two one hour runs at high revs with no sign of excess vac. in the Racor. Inevitbaly a complete mystery but fingers crossed. I have a diagram of the 300 gallon diesel tank somewhere so will look out how the pickup works. Someone else suggests that the "washer" the ball in the Racor sits on if installed upside down can cause exactly this problem, but I didnt take the Racor apart, and dont entirely follow the suggestion as a cause.
There would only ever be a partial vacuum, and a small one at that, in the filter. Once the lift pump starts to draw fuel, atmospheric pressure in the fuel tank will immediately start to push the fuel through to the Racor. The light ball will lift immediately and the fuel will flow through the filter and on to the pump. Of course, if there is a blockage somewhere, such as the filter itself, then the vacuum on the pump side will start to rise.Just mulling over this vacuum thing. Presumably, unless the Racor is gravity fed from the tank which mine isn’t, a vacuum in the Racor is necessary to draw fuel through from the tank and into the system. Similar to a raw water strainer. Or am I missing something? Obviously the vacuum should be within acceptable limits.
Was editing my post as you repliedThere would only ever be a partial vacuum, and a small one at that, in the filter. Once the lift pump starts to draw fuel, atmospheric pressure in the fuel tank will immediately start to push the fuel through to the Racor. The light ball will lift immediately and the fuel will flow through the filter and on to the pump. Of course, if there is a blockage somewhere, such as the filter itself, then the vacuum on the pump side will start to rise.
Richard
