Anti-siphon loop for engine
Once you are below the 32 feet limitation all that matters is the weight of water in the two sides of the U-column. Simply put, the heavier side will always pull the lighter side over.
True, I don't think that works when there is a pressure limiting factor at work, like the liquid-vapour transition above 32' head. The pressure at the top of a 20' column is lower than the pressure at the top of a 10' column, so fluid will flow at a rate where the friction head balances things out, but the pressure at the top of a 60' column is the same as the pressure at the top of a 40' column, so nothing needs to flow.
The 32 feet consideration is all about air pressure and whether the weight of the column of water exerts more or less pressure than atmospheric. In normal circumstances this is only relevant to the higher/source water level.
Richard
Bit like a halyard when you let go of it!
i undestand what you mean!
Stu
No need to assume: "Retired industrial Chemist".
Yes I know that. When we meet Vic several years ago, 2005 I think, we had a long chat and had Tea with him and his wife. I seem to remember Vic did some work in a lab which I think was attached to a school of college but my memory is going a little.
Sorry Vic if I am giving your secrets away
