MGsailor
I'm thinking of installing a planar (autoterm) heater this winter, they do a marine kit with all the essentials. But I do not know the best location. At present, I am thinking in the void behind the cubby-hole above the sink, this comes away with only 4 screws so access is easy. There is plenty of height to ensure the combustion air inlet/exhausts are more than 60 cm above the waterline, but the width of the space here here is a bit marginal. On the plus side it is easy to rout the trunking to feet level at the helm. Has anyone a better solution?
On another topic, I have the opportunity to buy a 5hp short shaft (17") auxiliary outboard. The 140hp Suzuki I have runs beautifully, has only done 550 hours, but I feel I should have a back-up. There already is a 4-position outboard bracket on the transom which is rated up to 9.9hp. Would 5hp be enough for the Antares 7.50?
I would be grateful for any views. I've been a sailor for 40 years but have finally moved into a motor boat for the first time!
