curiouskb
Thanks for the feedback I will try and find a Alumina 10 ALX to look at in the flesh.
Take a look at the AB Mares VSX model. I am using the 12 feet model and I prefer glass to aluminum.
Have a look at ab inflatables http://www.abinflatables.com. The aluminium model beats everyone in terms of weight. We've got the the Alumina 12 (3.6m) and its 140kg without engine. It's a serious tender, you can stand at the helm and the finish is impeccable.
Generally on the small dinghy/large outboard combo. I would always install a 5º wedge. They make a huge difference. Keeping the nose down is not only good to get on the plane, it's also about using the bow to cut thru the chop. Once you trim all the way down you can feel the engine working harder pushing the bow down, bit what a difference in the ride in choppy waters. A total must.
The former. It's just a thin spacer that you fit between the rear of the transom and the o/b mounting plate.What is a 5 deg wedge? Is it an aftermarket product or a design feature built into the hull.
Blimey M, for a minute I thought you went bonkers, while reading this.Did a 300 mile round trip recently
I Thought you could fill the tubes with petrol - well it is lighter than water.Blimey M, for a minute I thought you went bonkers, while reading this.
I was already thinking to ask how many cans of petrol you had to carry...![]()
Progress so far
The Zar ZF-0 is winning the votes at the moment SWMBO likes all the grab rails and well supported seats and the Italian style does look gorgeous. Its not expect to be ready until the end of the season though.
So with a 30hp outboard and fuel we are approaching 300Kg and we need a about a 300/400mm between the transom and the tender to squeeze by. So the tenders going to over hang the bathing platform some 600mm so now it time to seek out some experts on If the T44 and its bathing platform will support it and some aid to the passerelle lift like Hurley davits. Hurricane has given me some confidence of having a go however.
Its certified for 5 (or IIRC 800kg) that would be OK back across the river from the pub etc but for further adventures 4 max, cannot tell the outright performance yet as being a good boy and running in the engine (Suzuki 20hp) as per the manual ie no more than half throttle, but it does go on the plane with 2 at that setting.Looking good! What size engine? How many adults can you take and still be on the plane?
