Baggy
My new set up is a Battery close to the Bow Thruster fed by a charge cable from the Starter battery and Alternator when engine is on
The charge cable is 16mm2 on a 8 mtr run rated at 50 amps
I have fitted 50 amp fuse at BT batt end, and a 50amp cct breaker at Starter Batt end, via a batt isolator switch
The trouble is I keep blowing the 50 amp fuse, probably due to the BT batt dragging in high amps from the Starter batt/ alternator
Is their a way of restricting the Amp flow to BT batt to say 30/40 amps,
other than using a B to B charger ?
