GHA
Someone else might be able to crunch the numbers, but using polyester instead of nylon will definitely increase the load on the anchor. First he says use nylon, which is widely agreed as a good material to use, then suggests a halyard or sheet, which almost certainly will not be nylon.Why is this bad advice? it all stretches better than chain so anything will act as a snubber with varying degrees of stretch
