Hermit
I suppose if there is nothing on TV/YBW we could always watch our anchors. Will this be the new video trend by livaboards?
'Baby monitor' for anchors launches
Wifi won't pass through water (well, maybe it would a limited depth of fresh water, but none at all in salt water)So how does that connect to your phone at the surface? Does wifi work underwater?
I think the camera is in the anchor line just a few feet up from the buoy. The bout is just an antenna.
Only works in clear water - you're quite safe from East Coast sailors posting such videos! And we can use whatever anchor we like, safe in the knowledge that no-one will ever know!Excellent, we can all do Panope style anchor videos. Endless scope for rows about anchoring ☺
The second shows far more detail than it would in realityBeing an East Coast sailor I thought I would post simulated anchor views.
Calm water.
Tide running fast.
How about a partial glass bottom and a pair of binoculars.
Always enjoyed those tripper tours in the Med .
That set my mind a-wandering, and I thought of the access boxes above the props on a lot of narrowboats to allow weed and shopping trolleys to be removed. Granted they'd take up a bit of space, but a few of us would have found them pretty useful at times. Are they really so impracticable?Not such a daft idea...
Someone of repute of the racing fraternity in Hong Kong had a glass panel, presumably acrylic, installed so that before the start of a race they could check that the prop was fully folded. I imagine this worked well for a prop but an anchor is a bit further away (or down) and water clarity dictates what you can sensible see.
Jonathan
Ah, my understanding was that the perspex was to observe wether the several thousand (add currency of choice) shaft decor was doing it's thing, as I assume that any decrease in speed under sail was, apparently, too subtle to ascertain in the case of a deployment failure.Surely the better thing to do is fit a folding propeller rather than fitting a perspex panel.
