rgsmg53
I've currently got my boat out of the water - first time for this boat in my ownership.
I'm doing all the usual stuff such as anodes, anti-fouling, etc and I was just about to replace the trim tab anodes. There is one anode per trim tab and they are on the upper side of each tab and bolted through the tabs themselves. So, here are the silly questions:
1. Is having anodes on the upper sides only the right thing to do or should there really be anode material on both upper and lower surfaces? I'm conscious that with the tabs "up" (most of the time on the berth) the lower trim tab has no line of sight to the hull anodes.
2. As neither of the trim tab anodes are bonded electrically to anything else, should the anodes be in direct contact with the trim tabs or should they be fitted with the normal insulating pads underneath.
What do you experts out there think?
