Alpha22
I have an elderly motor cruiser and due to damage I'm having one shaft replaced. Currently all the underwater metal is bronze, except two stainless trim tabs.
Current anodes are two pears located on the underside of the hull immediately above each shaft. The new replacement shaft will be stainless steel.
McDuff's website says anodes should not be electrically bonded to dissimilar metals and I think I almost understand why.
SO...... what anodes should I have fitted? What should be bonded to what?
I'm thinking I should add a donut on either side of each trim tab, but what to bond each pear anode to? The shafts currently are not specifically bonded in any special way.
