gandy
Hi,
I need to replace the hull anode, it's a standard pear shaped bolt-on, on a GRP hull. As usual by the time the anode needs replacing, the ends of the studs and particularly the mounting nuts are pretty corroded. Thinking about it I suppose the galvanising would have eroded in the same way that the anode, so would have disappeared pretty quickly.
What are the thoughts on using stainless instead? Any benefit, or would it screw up something?
Thanks, Tony S
Thanks, Tony S
