Carols
Active Member
Any comments on what is the best to use for anode fixing studs in hull silicone or sikaflex
waterproof welding
Sikaflex 291.
Sikaflex 292 then!for this application, studs for anodes, you do indeed want the "welding effect" else you risk the studs turning when you undo the nuts. I therefore strongly recommned 3M 5200 here, not sika 291
This is getting daft. You are now arguing using one isolated example to prove a general principle. If your threads happen to run easy because you've luckily not had them corrode a bit or the boat has only been in the water for a year, or you used uber quality greaseor whatever, you could probably use blu-tak. However, that isn't the general case. In general, threads seize, maybe cos the boatyard used nasty grease or no grease, and/or you get a gorillas in boatyards with big spanners, and so there are plenty of scenarios where 5200 would work and 291 would fail, due to 5200's 3x strength. The fact that in your particular (perhaps lucky, perhaps careful) case you didn't need its strength doesn't change the general principle that anode bolts fall into the category where you want them really well glued (welded) on.In my view the important thing is the I initial seal and not to disturb it. This means someone holding the inner stud still if necessary.
However, I replaced the anode studs on my boat last year and sealed them exactly as described, with 291. I then secured the anodes outside the inner securing nuts with doubled nuts -I plain, 1 nylon. Nipped up moderately hard. This year the nuts freed easily, but none had slipped at all, and when I did the nuts back up with the new anodes they didn't even flex, let alone move.
