Piers
When checking continuity between and anode and something to which it's bonded, is 0.2 ohms too high?
great result piers and it's nice to know it has been checked and confirmed. I think you are way over egging the contribution of grease to all this though!Yesterday was a good day in the enghine room.
To double check continuity, I borrowed a much more accurate meter and found all bondings and anodes to be less than 0.2 ohms, mostly between 0 and 0.1.
Furthermore, and as rceommended by super-engineer Dave of M&G (Guernsey) I used a small smear of Evinrude Johnson Triple Guard Grease on the brass plugs when re-inserting the engine and stabiliser oil cooler anodes. Result? All registered 0 impedence to ground. How good it that?
So, lessons learned - use a really good meter, and yes, it's OK to use the right grease when re-inserting the anodes to enable easier extraction as well as stopping the small amounts of metal to matal corrosion.
Out of curiosity, do Fleming bond all the seacocks back the hull anodes with cable?
