Plum
Before launching I always check, while under the boat, the electrical resistance between hull anode and prop is less than 1 ohm.
Now with boat in water while checking engine I measured the resistance between anode stud and propshaft at 30ohms. Not good. Suspected my "electro eliminator" MG Duff Electro Eliminator for Shafts up to 50mm so cleaned shaft and brushes but still 30ohms. All connections cleaned, no change.
Disconnected bonding wire from anode stud and measured between wire stud terminal and shaft 0.2ohms!
Measured voltage betwee that wire terminal and anode stud as .027v. Obviously I would expect a current flow if the anode is doing its job but did not expect it to be measurable. So was that current flow affecting the resistance reading of my Fluke multimeter?
(Batteries were completely isolated and no mains connection)
www.solocoastalsailing.co.uk
