A
Anonymous
Re: Anti-Siphon Loops - How they work
I have also seen a small hole used as Lemain describes - small enough to not need ones finger to go over it. I believe that what Lemain is describing (perhaps he can say if this might be so) is that the valve is extended upwards on a piece of hose so that it will not tend to dribble through the small hole when water is passing through the loop.
[/ QUOTE ]Well, John, I'm not quite at the dribbling phase myself /forums/images/graemlins/laugh.gif What I've got is a loop of transparent pipe that loops upwards - like one of the humps on the Loch Ness monster. On top of the hump, the pipe has been cut and a plastic fitting inserted. This fitting seems to be a straight-through with a small hole on the top. If you put such a device on the outlet of a pump, then you'd get a spray of water coming out from the device, like Moby Dick. If you put this on the foul outlet of the toilet the consequences would be indescribably disgusting. One added part of this 'device' is a white plastic object in the pipe connected to the suck side of the device - this seems to flow with the water and floats back up to the device during pauses. I suspect that it is to prevent foul water from getting into the flush circuit should a gross defect have occured in the toilet. Aside from the little white plastic valve, you could probably achieve the same result by drilling a small hole in the plastic pipe, but then you might get a little dribble, I suppose.....
We don't have any dribbling on my boat, of any sort /forums/images/graemlins/laugh.gif
David
David
