Boo2
Hi,
Following a lead here I went out and bought a 125mm angle grinder from Lidl and I have a couple of questions :
Firstly, is it normal for the grinding disks to have a bit of runout ? The supplied cutter disk has almost 1mm of runout but I substituted a diamond wheel and it seems to be the disk not the machine.
Secondly, can you use the normal cutting disks on ally as well as steel ?
Finally, has anyone used an angle grinder to polish the gel coat of their boat ? I see you can get polishing mop kits for them and I wondered how well they work ?
Thanks,
Boo2
Thanks,
Boo2
