Greenheart
The time of launch draws nearer...(I hope!) It was even sunny today, although temperatures stayed resolutely in single figures.
The varied assortment of things that have troubled me about my new old boat, is slimming to a few that might actually cause genuine problems.
My self-bailers are tired and old, and don't lie flush with the hull. Should I haul them out, clean and re-bed them in mastic? Or just replace them?
I suspect someone around the twenty-stone mark must have helmed the boat. Two nearly-invisible cracks in the side-deck widen alarmingly under any serious pressure. Is it something I could solve by injecting epoxy into the cracks?
At some point there seems to have been a serious accident, possibly on the trailer. The 'mend' is very rough and will surely leak...but as I don't mind about compromised performance, will it be enough to sand off the loose paint and cracked filler, then apply new gelcoat? I only want it to be a safe, permanent repair, unlike the dry, crazed, powdery filler there now.
When I tilt the boat back on the trolley, I can hear several litres of water sloshing down the port side buoyancy chamber. I've removed the tiny bungs but I can't locate the water. Any ideas? I'm thinking a thin plastic pipe and a syphon...
