Neeves
Yawing and Veering - I suspect that most people here know exactly what is being discussed when the words are ascribed to a post on anchoring. If they have not known what the words mean - they are not very inquisitive.
Now I'm interested as I've never tried a riding sail.
In an anchorage where the wind is coming from variable directions due to a headland, some valleys down which the wind is funnelled etc etc and the yacht is veering (or yawing) - or if you prefer yawing (and veering) to every bullet and gust - does a riding sail help? It does not require anything as large as a headland nor valleys to create these gusts from variable directions - just go to any airport (that is still operating, most in Australia are largely mothballed) and go when its a bit breezy. As the planes c come in to land they veer (or yaw) all over the place - yet the geography round the airport can be flat. Wind veers or yaws simply because of friction with the surface, lets complicate the issue and call it shear, or is it sheer? As Thinwater says when you sail and are sailing to the wind even out on open water you are constantly trimming a sail or altering course - simply though lifts and knocks - and when you are racing the wind is always stronger (more pressure in modern parlance) over there where the competition is making hay and you are wallowing in a calm patch. Now I understand that lifts and knocks don't matter when you are cruising, and matter even less in a cruising cat
when you are on autopilot - but they are still there).
In my complete ignorance a riding sail will only make matters worse as the gusts will impact an even larger side (beam? preferred word) area - but maybe I've missed something.
I confess our solution is to assess the angles of the gusts and set two anchor to accommodate, not the extremes, but the averages of the directions. This allows each anchor to be tensioned in its set direction and the 'V' of the 2 rodes stabilises the yacht. Setting the anchors to the dominant gust direction means that the weakness of any anchor to side loading is reduced and Panope's recent results are less applicable.
So tell me how a riding sail manages this common situation.
I also assume that people who are subject to veering (yawing) or yawing (veering) as a result of some intrinsic 'design' of their yacht (dinghy on the foredeck, big rolled up 150% Genoa) know to remove these devices and maybe deploy some form of hammerlock should the movement of the yacht cause discomfort. They could also deploy a second anchor (as everyone carries one, don't they?). They could also deploy a riding sail (which might be easier than removing a 150% Genoa). As I say - I can see a riding sail exacerbating a variable wind direction and agree a hammerlock might help tame it.
We carry a spare anchor (or 3) and each can be used as a primary. To me, being parsimonious, it is simpler to deploy a second anchor than deploy a riding sail (less easy as we have no backstay) - each to their own - and I'm not convinced (and I'm waiting to be convinced) that a riding sail will calm bullets.
Jonathan
Jonathan
