[2574]
I'd be interested to read of your experiences so far with the Epsilon. Are you pleased with it?I sold the Knox anchor to ansarkit. To be exact it will fit the CO32 anchor locker but it is very tight, tricky to retrieve and will only come out one way. This is made worse if the chain shifts under it at sea, when it can be impossible to remove without shifting the chain beneath the anchor. Not great if you are in a hurry.
The Rocna I now have is similar but a little better. I have 45mts of 8mm chain which meets most coastal circumstances in the Channel except, at times, around the bay of St Malo. I have some lengths of nylon for these times but don't attempt to stow them in the chain locker. I dig them out as needed, which is seldom; they serve double duty as long lines for rafting etc.
I may be selling the Rocna ( has anyone had more anchors than me?) as I now have a new Epsilon which, being quite short, is a much better fit but as yet it is still in the shed.
I vaguely recall trying a Manson Supreme, for fit, once and I do recommend you look at that. I believe Force 4 will sell you one and refund if it does not suit.
Personally I dislike anchor rope and it would be a right pain in a smaller anchor locker, stowing 30m and 15m of chain under a 10Kg Rocna would be a work of art.
