castoffandgone
Yes that would work with one huge caveat. You said your boat reads below the 1.8m keel, so when you read 5m it's actually 6.8m so you need 8m of chain because the bow roller is 1m above the surface. Make this simpler for yourself and just add 3 to the depth reading![]()
Oops! forgot about that bit.
Regarding the setting of the echo sounder. We have ours offset to read from the bottom of the keel. the rational here was simply that the keel is the bit that will hit the bottom first (normal circumstances prevailing).
