craigsmith
---- said on these forums a number of times: tandem anchoring cannot be relied upon.
In total agreement : it is a relic of the days when the fisherman type was the norm, but I came across it again in a relatively recent book by a French 'expert' on anchoring.
As a result, and faced with staying in a Hebridean anchorage with ''F10, perhaps F11'' forecast for the area, I shackled my twin CQRs in tandem for the first (and last) time. At the height of the storm we were suddenly on our way to open water, with a lee behind Cape Wrath as our most likely salvation. Thanks to an anchor watch and a quick-starting engine, we got the ironmongery up before being driven into the big stuff roaring past the point half a cable away. We removed the second anchor and relaid the first, which then held hard in its usual exemplary fashion.
A few moments thought, and all became clear: an anchor designed to bury deep is inhibited by shackling anything to it: Tandem ? NEVER AGAIN!
[/ QUOTE ]You might also say you must avoid shackling the rode to the anchor, lest it prevent it burying...
Or perhaps your CQRs were set up in a similar fashion to that of the anchors of the skipper in this MAIB case study. No doubt he has been scared off using tandems too!
No slight intended, but you do not give details (you shackled the tandem to the trip-eye of the primary? that is incorrect!). If anything is learned by people reading this thread, it should be that tandem anchoring is a complex thing, and the theory must be properly understood, else it can do more harm than good.
It is the poor tradesman who blames his tools (or in this case, how they are set-up).
