SeamanStaines
Nostro, your ability to over think a problem exceeds even that of Sheldon from the Big Bang Theory!
1. You cant get closer (assuming you don't drag) to any obstacle than the length of chain plus the length of boat
2. Things always look closer from the boat than they really are (see how close an anchored boat that is worrying you actually is when you look at it from the shore)
3. With your draft you wont be messing around in water so shallow that you might run aground within a twenty or thirty meter distance.
4. If you really are feeling that brave that you anchor really close to a rock, you are going to set the kedge.
5. If you are worried about going aground because of being blown onto a lee shore, then you are in the wrong anchorage so move
6. If you think you might be to close, then no amount of measuring is going to convince you otherwise so you would not sleep anyway
As a general point, if its forecast to get windy then we set a wind alarm, shallow and deep anchor alarms, and sometimes a GPS alarm, but that is to detect a dragging anchor which is a different problem. If strong winds are forecast then I want to be blown out to sea without hitting anything.
