Anchoring mishap - beware nylon rode
kingfisher
7 Nov 2001
Belgium, Holland
This winter, I split up my anchoring gear. The anchor is in the nose, while the chain is in the back locker. This to improve weight distribution: the cockpit wouldn't drain properly, so more weight in the back was needed.
last sunday we decide to do a Club Med sail: go to the Springergeul on the Westerschelde (comparable to the Medway creeks), anchor off, unload the beach gear on the sand bar and enjoy the sand. 'We' is me, SWMBO and 5-year old Nathan.
We arrive at the spot, 1 hour before LW. As this is just a leisurly stop, I decide to forgo the hassle of dragging 15m of chain across the deck, and just attach an orange nylon warp. SWMBO received a crash course in anchoring in Turkey, so has absolutely no problems with taking the helm for an anchoring manouvre in sand ground like the Westerschelde. We drop the anchor at 3m depth, back off and let out about 15m of warp, the anchor holds instantly.
We swim for the beach, while Nathan gets ferried acros in a small inflatable (wearing his lifejacket, of course). On the beach we relax, read, frisbee, blabla, and get irritated by a motorboat that lands itself on the beach just in front of us, drops the hook on the beach, unloads passengers and pulls back 10m, right in our swinging circle.
The wind is from the side of the channel, and as the current abates, the boat starts to swing back and forth. Finally the incoming tide kicks in, but still the boat swings and veers. The wind constantly wants to push it over the anchor.
An hour later and the wind is up to a f3. We need to get going. I swim from an upstream position, but find it difficult to aim for the boat as she is swinging from side to side. I haul in SWMBO and Nathan on a line. SWMBO finds it difficult to get aboard on our stupid ladder which is just one step too short.
We start up the engine, I haul in the anchor line. All goes well the first 5m, but then the line is taut, without movement, and is pointing backwards. Uh-oh. I give and I pull, but nothing. Clearly the line has wrapped itself around keel/rudder/prop (or all of the above). After about 10 mins of pulling, I let slip the line and pray. Suddenly the boat is off. Thank God for slippery nylon. We do a large turn, I helm, SWMBO on the nose and she picks up the line at the first contact point. Good girl. We switch, I haul in. But before you can say "danforth", the line has curled itself round the boat again. Sigh. I let slip again, and we do the whole thing again.
While we are doing that, a RIB decides it would be a good thing to zoom through the anchorage at speed. We frantically wave at them, but they look at us like cows at a train. Finally they slow down, I point out the floating nylon line, but if they do want to sail over it, be my guest. They thankfully move off.
We pick up the line again, and this time we steer with the current against the wind and I pull in faster, so the boat does not get the chance to ride over the line. We haul in anchor and leave. My back still hurts.
Lesson learned:
- an anchor on a nylon warp will hold your boat. But I would not overnight on it.
- a chain or weighed line will sink from the nose. When the boat turns, the line is too deep to catch keel/rudder/prop
- on the other hand, the nylon line allowed us to retreive the anchor, once we slipped the line.
- our bathing ladder is one sport to short. With the current running under the boat, SWMBO could not pull herself up. Even with my help, this was difficult. Now, this was in 20° water, with no waves and she was wearing a bikini. Change that to 1m waves, 12°c water and foul weather gear, and a disaster is in the making. It was very sobering to SWMBO. I had already explained her a few times about using the mainsheet block and tackle, but now she begins to grasp the problem. And I am still not convinced that retreiving a MOB in full gear by myself would be possible. And I don't think SWMBO will be capable of hauling me out. We need to practice on this.
- floating nylon lines seem to attract MOBOs. Dunno why.
Searush
14 Oct 2006
- up to my neck in it.
back2bikes.org.uk
You could use a messnger weight to hold the rode on the bottom & improve the catenary. If you use the same 5x scope but put the angel at 1x depth you could have the rode straight up & down at the bow with a drastically reduced swing.
By the way, having heavy weights at each end tends to encourage pitching. Many smaller yachts (OK, so a Sirrocco 31 ain't small - but is it light displacement?) are designed to accomodate 2 adults in the cockpit and, if they are not there, sit a little down by the nose.
Aja
6 Nov 2001
Also. This winter get another rung attached to your boarding ladder. We were in the same situation a few years ago with a jet-skier in difficulty. We couldn't get him aboard.
Added two extra rungs.
Donald
ChrisE
13 Nov 2003
Kington
www.simpleisgood.com
Erm, did I read you aright when you spoke of floating anchor rode?
I'm not surprised you had problems, thought everybody used 3 strand or multiplat that sinks.
I've spent more nights than I can remember happily on chain and mulitplat in all manner of tide/current/wind change combinations with no probs.
Salty John
6 Sep 2004
UK
www.saltyjohn.co.uk
Are you sure you are not using polypropelene line? It is usually brightly coloured, shiny and it floats. Nylon and polyester lines don't float. Poly is no use for anchoring because it is not very abrasion resistant and it rapidly degrades in sunlight.
contessa26
4 Jan 2006
Scotland
Most interesting thread and account - thanks very much. Informative and amusing! Great! Glad everyone was all right, too! (inc the motorboat's prop).
I've used warp rode to anchor, but not floating line, or done so in tidal conditions. Interesting!
Best wishes.
KenMcCulloch
22 Apr 2007
Edinburgh, Scotland
I did start to wonder about this; Nylon rope usually sinks in my experience and given it's described as orange I suspect it is polypropylene which floats and is entirely unsuitable as an anchor warp.
A very interesting story clearly showing why you need the right tools for the job when anchoring.
kingfisher
7 Nov 2001
Belgium, Holland
It's one of those cheap orange-red lines that you can buy in every B&Q. I have about 30M on board and is usefull for:
snatching moorings, as it is very stretchy
throw-away rope for use on dirty lock walls
splicing instructions,
but not anchoring.
Anybody got some tips on attaching an extra rung on a folding ladder?
KenMcCulloch
22 Apr 2007
Edinburgh, Scotland
Only the light anchor (10kg) is in the nose locker. The chain and the heavy anchor (25 kg) are in the rear.
You, sir, are an accident waiting to happen /forums/images/graemlins/wink.gif. How are you going to get your anchor and chain to the bow when you are blowing onto a lee shore in a rising wind?
Searush
14 Oct 2006
back2bikes.org.uk
My yacht has a bow not a nose so I am totally lost!!
Paul.
Ahh, Bless the little pedant. So, where is YOUR nose then? Perhaps it is up your *rs* - hence the confusion would be totally understandable!
/forums/images/graemlins/laugh.gif
starboard
22 Dec 2003
N5533 W00441
What a delightful person you really are....your views on this forum are so interesting......not!
Paul.
Gunfleet
1 Jan 2002
Orwell
Expressed a bit more politely, if you look at Kingfisher's biog he isn't English, and it's generally not considered good form to criticise non-native speakers for footling 'mistakes' in their vocab.
starboard
22 Dec 2003
N5533 W00441
I am sorry "Gunfleet" but the bow of a boat is a bow in whatever language you speak.........but then again I guess you "reverse" your boat into its berth when you "park" it!!!
Paul.
Gunfleet
1 Jan 2002
Orwell
From the redbay boats website
'One of the major design features is the Hard Nose. This was developed due to several reasons, and has proven itself one of the most successful features on this design after many years in testing. The Hard Nose is primarily a safety feature. When a RIB such as this is driven hard in a large sea state, there is a real risk that detubing could occur. Thus, the nose is designed to offer complete protection to the tubes when operating in these conditions. Furthermore, there are actually two independent tubes on each side of the hull, offering even greater safety.'
Don't you 'drive' one? Your biog implies you do.
starboard
22 Dec 2003
N5533 W00441
Yes I do and a fine fine boat she is.....the hardnose is a design name for that particular feature on that design of boat!!!..... at the end of the day the pointy bit at the front is the bow....always has been always will be.........!!!!
Paul.
Gunfleet
1 Jan 2002
Orwell
This is real fred drift, but as a non motor boater I thought they looked great! The only trouble would be how much bouncing the passengers would put up with.
