BruceK
On my last outing, admittedly during one of the largest if not the largest spring tides of the year and near the southern mouth of the Menai straights where the current gets to about 4-5 knts, my claw anchor experienced it's first drag. As everybody was ashore at the time it gave me a bit of a scare with the boat dragging it's anchor at about 1.5 -2 knts at the time. Now I know these anchors in head to head tests have always performed poorly but mine has been absolutely reliable until now and that includes anchoring in some nasty weather up to storm force 9 this last August. http://www.youtube.com/watch?v=G5Y43EkTv5A
The issue that worries me most are the tide / current direction changes we get here of up to 8m. In this respect the Bruce / Claw has served me well so long as I avoid sea grass and caters to my shorter than ideal scope of all chain 3:1 (HW) and chain rode mix 6:1, the latter being rarely deployed.
I mostly anchor overnight and so what was different this time was an absence of an electronic anchor watch to give me warning and it was fortuitous that I noticed the boat drag as early as it did while ashore.
Based on the excellent reports I have read here I thought it would be a no brainer to go for a Rocna, or more specifically a Vulcan due to my boat's particular pulpit and bow roller configuration. (But then most reports were from the Med and my situation couldn't be more different) That's when I came across this video test which mimics my environment rather neatly. Fast current changes at 180 deg with shortish scopes in sand mud substrates. The Rocna did not perform so well. I seems the picking up of sand/mud on the blade upsets it's balance hampering resetting
Unfortunately further reading on what did survive these type of tests wont fit my setup. i.e. my second choice being a Spade (shank clearances) unless I attach it to the chain before each drop. Which leaves me with a Delta which I have even less confidence with having seen them drag more than set. What else is there that can fit my bow roller setup with that awful porpoise nose I have sticking out as shown below?
