aussi
Well, I did ask for opinions
Obviously I’m more interested in opinions from people who actually bothered to take a look at the app. I built this for myself as I know that when I get tired I can make silly mistakes when doing tidal range calculations in my head and it’s useful to have a cross check. I therefore suspected it would be useful to others too, especially those who have a bit more trouble with maths.
Thank you to those who have taken a look, it sounds like it’s working well across a range of devices, which was my main worry. Thank you also for the suggestions and bug reports:
A.
I’ll take a look at that red screen error, I think it’s from the tool that I used to build it - although the app doesn't need an Internet connection, the tool does check for updates.Worked on android oreo 8.1 mostly, but one time going into it got an error "Could not load request from https://exp.host:443/@aussi/anchorbuddy: the request timed out".
Other thoughts are swiping left/right should work as well as tapping on help and about.
Good ideas, I'll look at those.Let people set dark theme
I wasn't going to introduce units, as you say they are only cosmetic. The note on the help screen hopefully explains this clearly, but if more people ask for it I might pop it in.Also , preferred depth unit (I know that is just cosmetic).
No, it doesn't.Does that imply it needs an Internet connection to work?
A.
