petem
If my electric windlass ever fails, how would I recover the anchor manually? All that turning the handle clockwise seems to do is tighten the clutch.
petem;6427195There's always a hacksaw I guess.[/QUOTE said:Just picking up on this Pete ,
The end ( none anchor ) should be tied to the bottom of the locker by some cord wrapped a few times so,s when the chain is fully deployed you can reach in a cut said cord —— quickly in case of a raid emergency bug out - sacrificing the holding gear .
Think about it middle of the night wind gets up boats all over the place dragging / tangling up - heading towards the rocks etc etc and for some reason there’s a problem getting yours up .
Don,t shackle it to the inaccessible floor of the locker , imagine trying to unclip that in the dark , driving wind / rain with the bow pitching up and down and wife on the helm .
You can allways tie a fender to it and return to recover later .
Eek, that's not going to be fun if I ever need to do it. I guess you have the pull of the boat in the wind too to contend with. Can't see SWMBO pulling it up as I drive the boat. There's always a hacksaw I guess.
Positively +1 ref. securing the chain end with a rope rather than a shackle, as a general principle.should be tied to the bottom of the locker by some cord
Reminds me of a weird situation I experienced several years ago, when the chain found its way inside a crack between two big rocks, which were almost touching each other.We didn't have scuba on that occasion. Even if you have full scuba I wd recommend a couple of these mini bottles-I have one (present from forumites after a cruise) and love it. Obviously it is meant as a full scuba back up but you can use it v easily to give you 10 breaths for a job like this. You need a full on scuba tank to fill it off course. https://www.sunderlandscubacentre.c...MImP-IjIP72gIVyOFRCh32ewTaEAQYBCABEgKPQ_D_BwE
Good idea, thanks. I'll get one! :encouragement:Get a spare chain hook - I used one like this
But it's much better to secure such cord to the locker ceiling rather than to its bottom, because aside from being easier to find somewhere to attach (the lower part of the windlass bolts, of the cleats, whatever), there's also a functional reason.
The typical emergency scenario is not when the anchor is dragging, because by definition that implies that you can recover it.
It's rather when it's stuck and you can't recover it, but you need to escape PDQ for some reason.
In such situation, normally you don't want to release all your chain first and go to cut the cord afterwards, because the boat might drift toward something hard in the process.
So, it's preferable to have the cord inside the locker hanging from the top and always reachable, in order to be able to cut it first, and then let the chain go while you are already maneuvering to escape the dangerous situation.
I guess this can seem a bit of hair splitting, but as anyone who has been at the bow in the middle of the night with the boat pitching and rolling know, in such conditions every minute counts...
Depending on windlass type you could dump the chain or from the loose end flip it out the gypsey if this is not possible. Mine attaches to the forward bulkhead 1/3 the way up and can get buried under chain, but moving location would but it on a structurally weaker area should windlass / gearbox ever structurally fail and no snubber was deployed. (I have a vertical windlass with a option to quickly release the clutch so either method works well enough, my bitter end is long enough to escape the chain hawse but not long enough to bind to the windlass so can be cut without having to reach into the locker)
Look on the bright side Pete. After you've retrieved your anchor by hand, you'll have burnt so many calories you wont have to go to the gym for a month and very likely, your chiropractor will get richerIf my electric windlass ever fails, how would I recover the anchor manually? .
Peter
Have a look at the Alderney Ring Method. Google/YouTube is your friend. I have used this successfully many times whilst fishing and depending on circumstances it works well. I found that a large ball fender works best. suggest you practice in the lagoon.
Hi D
Does that technique work with chain.
We used to use that technique (didn't know it was called that) on a certain reservoir that you know.
Yes, it certainly works.
We were doing it with 4.3m RIBS and raising ground tackle up 80 feet.
The rode was mainly rope though - but there was about 10 feet of chain and an anchor at the other end.
From memory, we had a stainless steel hoop with a carabiner to stop it coming off the rope.
