noelex
You only have to do some rough calculations to see the gains in holding power by placing the maximum possible weight in the anchor.
If we 50m of 8mm chain. That weighs 72.5kg and say a 15kg anchor= total weight 87.5kg.
How could we better distribute this weight.
If we went to G7 chain we might be able to go down to 6mm. That weighs 42.5kg for the same total weight we could fit a 45kg anchor. This is obviously silly, we could never fit an anchor that big ( what great holding power if we could) but it illustrates the principal of placing the maximum weight in anchor and the minimum in the rode providing your selection is compatible with other requirements such as abrasion resistance, strength, and the swinging like other boats around you.
You can do similar calculations yourself, on your own sized boat, with your preferred length of chain and weight of anchor substituting a combination of a lighter rode and heavier anchor. The overwhelmingly obviously higher holding option is always more weight in the anchor providing the selected rode is adequately strong and abrasion resistant.
