JimC
Why not use a hammer lock?
Secure with nothing to catch on rollers etc...
What is a hammer lock?
Nothing to stop you doing exactly the same with a stainless steel shackle. My testing showed stainless shackles generally to be stronger and more reliable. Will hacksaw easily.
Yesterday I removed my galvanised shackle between the anchor and the chain. I replaced it with a S/S shackle having discovered that the working load on the stainless version is hugely superior to that of the galvanised version.
Apologies if this has been covered before. I use a D shackle to attach the chain to my anchor. The pin of the shackle catches in the bow roller when recovering the anchor so I would like to change it for one of those flush-pin shackles that you tighten up with an allen key. My query is; how does one lock such shackles? Using Locktite or deforming the threads with a centre-punch are two possibilities that spring to mind but neither seems to me as secure as wire-locking a conventional shackle.
If you are prepared to consider that option you might as well follow the advice of Eric Hiscock in 'Cruising Under Sail' and fit an ordinary shackle, then saw off its head and finally rivet over the protruding thread with a ball pein hammer. That won't come undone and, being mild steel, it will be easy to saw it off if you ever need to.
It's only just occurred to me that, when recovering the anchor, it's the pin end of the shackle that's first to reach the bow roller; so surely the fact that the bow is as wide as the pin would be no help because the bow hasn't got there yet (I have the pin through the end link of the chain and the body of the shackle through the slot in the anchor stock).
So, am I best to use a SS shackle to join a galvanised anchor and chain- because it's stronger than a galvanised shackle would be? I have just taken my ss shackle off to replace it with a galv one!
http://www.islandchain.com/
Scroll to the bottom- labelled Connector Links.
Hammer links have a very good WLL and would be perfect for this application.
I have used dozens of these in commercial applications and have never seen one corrode so that I would be concerned and I have never seen one fail.Unfortunately I have never found any that were corrosion resistant at all. Not galvanised, at least the centre pin, and not stainless.
That's interesting. I have always put the pin of an anchor (bow) shackle through the anchor. I researched this subject some years ago and found this to be the correct way and, I must say, it makes sense to me. I wonder what others do?
The 'slot' through the end link on an 8mm G30 DIN766 chain is 16mm x 12mm, so should take a 10mm shackle.
