Your formula is fine. However, it very rarely applies - only in light and steady wind conditions. The normal situation is an oscillation. Initially a boat at anchor will set up a small fore and aft surging oscillation, which, in stronger winds, becomes a side to side 'tacking' oscillation.The formula for chain, for the chain to be just horizontal at the anchor, is:
L = sqrt(D^2 + 2 x Lambda x D);
Where L = length in m
D = depth in m
Lambda = horizontal pull in kg you want to sustain / weight of chain per m in water.
...The forces in the rode when movement is reversed (reversing the boat's momentum) are many times higher than any static forces, making static forces irrelevant. And they will routinely remove all significant catenary from the chain. Bar taught, you might say. Hic.
right with ya there....let it all out, if there's space..can do no wrong3 times depth AT HIGH WATER taking into account any echo sounder offset plus the height of the bow roller from the water. If it isn't going to blow.
Fair enough, but why keep any chain in the locker if you have swinging room?
- W
It is the depth of water where the anchor is that is important. So if you anchor was dropped in 20m (from anchor roller to the bottom) you only had a ratio of 50/20 :1 (2.5 : 1) despite ending up in 5m water.What complicates things, at least to my mind, is where the bottom slopes - eg last week in Turkey (SO 36i) I dropped my anchor in 20m, but by the time I had let out 50m of chain, I was in 5m, with a line ashore about 20m long. I felt secure, but would be interested in any rules of thumb for dealing with sloping bottoms.
Regards
Neil
Can someone please point me to a calculation method for chain rode length/ depth of water. I'm not looking for 3:1, 4:1, 5:1 etc, but one that I have seen on this forum a few times that I think depends on the square (square root?) of the depth, rather than depth itself, to increase proportionately for shallower water.
Links to various spreadsheet and graphical methods not required, thanks, I reckon I have them all.
Thanks for all replies.
My biggest problem in anchoring around Mallorca is that the anchorages are quite crowded. I let out 5:1 scope but doubt that my neighbours do, so worry that when we swing with the changing wind that we may meet. No real answer to this other an watch as others anchor and try and calculate how much they have let out and estimate the distance from them to me! No formula for this!
Generally hate anchoring as a result.
Tudorsailor
