Pete7
Doug, were have you seen a Spade S60 for £280 ? They were a lot more than the Rocna when I was looking a couple of years ago. Settled on the Rocna in the end, don't they have thin shanks compared to a similar sized Delta
The Spade is £255 here:
http://www.spade-anchor.co.uk/S60.htm
I know we all love an anchor wrangle. But here is a real, proper question. I have a 4ton 32 foot boat and am considering a new anchor. I have a choice of two:
10kg genuine spade S80
10kg genuine Rocna.
Both are about £280. They are for general sheltered anchoring in Northern Europe, not survival conditions.
I have narrowed it down to these two, so won't be considering any alternatives.
The question is which one would you pick? The Rocna or the Spade?
. Anchor holding is about area not weight.[/QUOTE said:But a bigger anchor that has more weight also has more area, type for type. So bigger is better-apart from the back.
Must have had a good blowlamp!Lead M.Pt 327C, Zn M.Pt 415C
Casting your own anodes can work but you must take steps to ensure that there is not even the faintest trace of iron/steel in there. Iron inhibits the anodic reaction of zinc in microscopic levels, should be less than .0014% to comply with the Mil Spec A-18001A.
I would choose Spade based on the consistency of test reports in France. It may have a slight advantage over the Rocna in weed.
Rocna is nevertheless a fine anchor and almost the equivalent of the French FOB Roc.
Crikey - my number are more like Fahrenheit (+ quite a lot more!). I'll think I try making a casting in some plaster with the new anodes and, if that goes well, I'll bring the old ones back from the boat and give it a go. I'll need something to melt the zinc in. I wonder if a stainess steel pan will release too much iron into the zinc?
An aluminium pan might be best as anodes can be aluminium so presumably that's 100% suitable? I'll have to be careful not to melt the pan though!
Copper or brass would be good I suppose although I'd have to buy a small pan of some kind specially.
Any other ideas anyone?
Richard
Spade is a French product so the French test reports are about worthless
I melt my zinc in an iron ladle, which I used to use for paying deck seams with pitch. It has not had any bad effect on the working of the anodes that I have made.
Do not buy a S80 that weighs 10kg!! You might be being shanked
An S80 weighs closer to 15kg.
.......Jonathan
