Neeves
Point of detail, my recollection is that 3: 1 was the rule of thumb for fisherman anchors.
4:1 became recommended for more modern anchors like the CQR.
When the Bruce became available, it was marketed as one that worked on a shorter scope.
And scope was measured at sea level. You let the anchor out until the relevant marker was submerged. If the wind blew up you let out some more until it was again submerged. And to the next marker for luck, maybe.
What are these markers to which you refer?
Modern cats, like a Lagoon have a high freeboard, I'd think nearer 2m. With your recommended 4:1 for a CQR that means deploying a 14m rode (with less for your idea of a Bruce) with a 3.5m depth. 4:1 might have been an acceptable rode, but I doubt it, 50 years ago - with smaller yachts
I think not - unless its lunch only.
Ours is a 38' cat, less freeboard than the current production cats - at 3.5m depth - assume no tide, good forecast - I'd deploy 25m of chain minimum (and because our chain is marked at 10m intervals - my wife would deploy 30m). If we had only room for 25m - we would go somewhere else. If its that crowded we would move - and often have. Too many idiots trying to squeeze into a small space results in people using stupidly short rodes which simply don't factor for an error in the weather - forecasts are not a certainty. We sail as enjoyment and crowded anchorages at best are noisy and worst mayhem.
Jonathan
