ontheplane
Was down on the boat over the weekend....
Have fitted oversized trim tabs to try and help with the main problem of the boat - its underpowered and has trouble getting on the plane.
They have helped enormously, the boat now planes much much more easily - however not actually much faster!
Whilst it comes up on the plane at lower speed, and I can then raise the tabs and she will still plane, provided the throttle is wide open, throttle back and she'll drop off unless I lower the tabs again.
So I have to accept this boat is chronically underpowered for whizzing about the bay.
I just cannot see any solution other than to re-power, however I have always felt that unless an engine blows up, you are always better off taking the money for a re-power, selling the boat and putting the two amounts together and buying a better / newer boat that is powered how you want it.
However, to buy a 22ish foot diesel cruiser with around 5'10" headroom in the cabin (i.e. not a cuddy) it's gonna cost a lot more than is available....
Does anyone know whether secondhand diesels of around 200hp (perhaps with a drive leg as well as the gearing etc may well be different) ever come up, and if so what kind of costs - because if it's £5000 or so, it's just not viable.
I would only consider re-powering with a petrol (replacing current petrol) if it was an EFi and MASSIVELY cheaper than the diesel - it just doesn't seem worth it otherwise.
Any ideas guys?
Any ideas guys?
