jmp
Does anyone know if there is a simple way to fit an ammeter to a marine alternator/diesel engined electrical system.I have 2 batteries with 1-2-both isolator.Also thinking of fitting an alternator regulator.
My simple mind says fit ammeter between pos wire & battery,but worried in case unit fails and isolates alternator from battery.Also at present alternator goes to heavy lead on starter,with domestic supply frcm battery terminal.Presumably it is not wise to have starter current running through the ammeter!
Am I right to take alt output to battery and combine with domestic supply through the ammeter ?.Still however the isolation problem if ammeter fails etc.
