aluminium window corner brackets
smitch6
Active Member
28 Jun 2017
on my aluminium windows i have small brackets inside the frame that are held by 2 small screws on each side
all the screws have stuck solid and i had to drill them out
does anyone know if you can get these brackets anywhere pls
i have searched and searched and cannot find any anywhere.
making the brackets themselves are actually quite easy as they are only mild steel so either get some thin steel plate and cut them down.
it's the holes that i am finding a pain as they are quite thin
the holes need to be drilled then tapped as there should be SS bolts in them and not wood screws (which is what someone has used on mine) which is why they have rusted
i think it would be loads easier if i can get hole of a pillar drill for 1/2 hour
