ianj99
200w of solar will deliver around 15 amps but only from about 10 am to about 5 in summer so you would be ok then.
The challenge of running a big engine lightly loaded for long periods to just charge the batteries is too risky. I'm with the suggestion of fitting a generator. In fact then you could do away with the solar and just drive your current shore power charger and the laptop off 220v
I agree. I've concluded that if fitting a substantially larger alternator leads to reliability problems with belts and bearings then its not worth it. Relying on the main engine as the only source of power is risky anyway as it can breakdown for numerous reasons in addition to the side effects of charging system upgrade. (advancing years = less risk adverse attitude!)
The only reason I would fit massive battery capacity would be if it was enough to last until the next shorepower outlet with minimal recharging en route.
