rafiki_
Final prep for Rafiki's Safari to Southampton, and stb engine alternator not charging. Thought it might be the drive belt, but no such luck. No voltage out of the regulator. Any thoughts?
When the engine starts, the tacho spins up. After about 5 seconds, the alarm sounds, and tacho's to zero.Is the tachometer working on the dodgy alternator side?
Many thanks Jimmy. Not sure what make, as the engines are Cats. Likely to be USA supplier. Regulator looks like it comes off the alternator. Advance, the local Marine Techies have the alternator, and will get it tested in the morning. Planned to lock out at 10 am tomorrow. Looks like this will slip to Wednesday. If this happens, the trip is still doable, as the wind low around Land End on Thursday. Blowing up Friday and Sat atm, so need to get round before then.Sorry to hear that P. When I had a prob with the regulator on one of my alternators, it transpired that you couldn't separately access the regulator and the entire alternator had to be replaced. The OE manufacturer was Mitsubishi and it was significantly cheaper to buy it from an alternator specialist using the Mitsubishi part number than from VP. Best of luck with it.
Was getting 15v to the alternator. Don't dispose of your spares yet please��Just to add to my earlier, tach is driven from the ac windings, if tachometer works but no charge then the regulator, if no tacho then possibly an issue with the power to the alternator, check the pop out circuit breaker on the box at the back of the engine, on mine it's blue. Just so happens I upgraded both alternators so old 55A units are sat in my shed, you are welcome to one if you want a second hand one.
John
John, many thanks for this. Alternator off and being tested this morning. Will let you know the outcome. I would be happy to take one of yours as a spare in any case. Could you PM me with cost please?It could be, the only time I have seen the same symptoms is when I have started the starboard while the geny was still powering the charger, I think it's because the charger holds the voltage high so the alternator regulator gives up trying to charge, the exact symptoms you are seeing, tacho works for a few seconds, then the lower charge light comes on and tacho goes to zero.
I guess what could be happening in your case is the brushes may be a bit worn, could be worth pulling the regulator and brushes and having a look, problem is the starboard is a pig to get at. When I changed the alternator the only way I could get down the hole far enough was to remove the complete starboard seat, I could not get deep enough just going through the seat hatch under the cushion. You should be able to get Prestolite parts at Dingbro, that's wher I got my upgrades, the marine alternators have an extra seal between the regulator and brushes, the part numbers I gave you are the marine type.
Let me know if you want me to ship one of my spare alternators
John
Yep, as per SailorSam, annoying alarm, no tachometer or pas, so best to fix here. Is ok to use the gennie while at speed?
Pas? power steering? Confused ere! OK I get the annoying alarm point though.Yep, as per SailorSam, annoying alarm, no tachometer or pas, so best to fix here. Is ok to use the gennie while at speed?
