Alternator woes continue 😢
Cheeky Girl
23 Feb 2004
Stirling, Scotland
Hi now installed the new alternator but the rev counter is not working now 😢. The Black/grey cable is connected to the W terminal. What can I now check ? Is there a way to see if the W terminal is working? Or is there another issue that we have caused ? The rev counter briefly showed a few revs on first startup with new alternator but now nothing 😢😢
VP2030 2002 boat
Stupid question ... Do you still have the old alternator ? was it working when removed ?
If yes to both questions - I would be inclined to put old back and see if rev counter is working ... if not - then I suspect counter has failed.
The question would then be ... Why ?
The inference is that the old alternator was producing electricity at its heart and the issue with it was peripheral - regulator, wiring etc.
The revcounter typically requires three inputs: +ve, -ve and W, which is the un-rectified AC output. It should be possible to check all of these with a multimeter:
Rev Counter - Fault diagnosis?
I'm on much the same venture as soon as I can find the boat's multimeter... :(
