Alternator top bolt size
jon and michie
28 Dec 2014
Hi does anyone know the bolt size for the top of the alternator on a kad 300 engine.
I think it is imperial as a m10 is a little slack and a m12 doesn't fit
Jon
Thank you for the help guys - will source a new one now I have surgically removed the seized one out of the alternator - which took around 3hrs to cut off the engine using a hacksaw blade then drilled a hole through what was left of the bolt then used a die grinder to weaken the bolt and finally a couple of taps with a hammer and it was free.
Not recommened or a pleasurable job so will be lubricatin the new bolt to try to prevent future seizing.
thanks again
Jon
