lumphammer
The engine is a Sole Mini-18 with an unknown manufacturer's alternator which has a separate regulator. I have just fitted a NASA battery monitor and found that the charging voltage is around 14.8-14.9 at about 3.0A. The Sterling instructions say that above 14.5 the regulator is faulty.
Is that probable? If so, will continuing to use engine charging damage the battery?
If I have to change the regulator I am thinking of fitting a new alternator instead of the existing.
Is there a formula that relates alternator size to battery capacity?
The output from the alternator on the cable to the regulator is marked A, F, N and E, and there is a separate B terminal to the battery. F, I assume is the field, E is earth.
Which cables should I connect the regulator to?
How can I tell if the alternator is N-type or P-type?
