Daydream believer
IIRC, it means "I think you will find".
Thank you- spent ages trying to work that one out
& IIRC ---- have we changed from Portsmouth yardstick ??:ambivalence:
You really don't need to replace it at all, if the positive is fused.
Because looking at the first photo it appears that the red wire is something added. Its does not seem to be part of the original wiring.
I think you should find out where the red wire goes and determine what its purpose is.
Ok guys the problem is solved. The main negative feed to the alternator had a fuse in the line which had blown. See below.
Question: I don't have a replacement for this. I think inmust have touched the positive to the nagatice and blown the fuse during installation. If I temporarily install it without the fuse, will this be ok and as an fuse the negative lead normal?
P.s red lead for the warning light was not going anywhere it seems. I think it was for a second alternator which the original owner had running in tandem.
