Ceirwan
Good evening, does anyone on the forum have any experience with replacing Yanmar engine mounts from a 3rd party supplier?
The ones on my engine are pretty much gone and while I'm all for OEM, at £100 ish a corner I draw the line.
I rang T-Norris who can supply an aftermarket solution (not sure on the brand) but that still came to £330ish.
I also rang AV industrial products who sell their range of mounts on eBay, the guy I spoke to hadn't heard of the engine but recommended their smallest marine mount that would take 50kg as suitable.
This would work out around £100 for the full set of 4 which would obviously be ideal, I would however have to drill and re-tap my bearers, which means taking the engine out, not to much of a problem but I'm wondering if anyone has used these mounts before I go down this path?
The other issue I can think of is that Yanmar specify two separate mounts, one for the rear and one for the front, which I imagine have differing stiffness's, wondering how much of a difference I'd notice with all 4 corners the same?
Has anyone got any thoughts to share?
