Algae on sails
C08
8 Feb 2013
My foresail having been left on the boat is bright green with algae but no mould. Strangely my inner foresail is pristine white despite being on the boat for the same period of time. What is the best way I can clean this algae off before storing it over winter?
SimonKNZ
7 Jan 2020
Auckland NZ
I spread mine out on the driveway then applied water and laundry stain remover. Leave to soak for a while then scrub with a broom. Didn't get rid of 100% but a whole lot better than it was
RobWard
17 Oct 2005
Wet and Forget seems to be the wonder algae killer of choice.
C08
8 Feb 2013
Thanks - Patio Magic on order. I will do the sheets which are black, mould I think at the same time.
C08
8 Feb 2013
I have mixed the PM @ 4:1 as on the directions and given the sail a light scrubbing all over with it. I note that the product info says that it can take up to 4 days to kill off algae? I have left the sail drying in the garden to see how it goes and then probably another scrubbing tomorrow. I am unsure when I have finished whether to wash off or just leave - any ideas?
Also what can I do to prevent the green creeping back?
Thanks for advice.
C08
8 Feb 2013
Now the algae is thinning I can see black which presumably is mould so tomorrow i think some diluted bleach followed by a PM wash off. Poor sail, it has only been out half a dozen times and looks 20 years old!
VicS
13 Jul 2002
Be careful with hypochlorite bleach on polyester sail cloth. It can turn the cloth irreversibly yellow. Try a small patch or try an oxy- action bleach such as Vanish
C08
8 Feb 2013
Thanks for the warning - a hard choice between yellow or black!
SteveIOW
3 Oct 2008
Isle of Wight
Have recently tried using Patio Magic to clean green algae from leach and foot of furling genoa (the UV strip is white). Mixed it at 4 to 1 and applied liberally with brush. Have left it for four days but there has been little or no effect and the green remains. Any ideas please on why it's not working.
Have done the treatment with sail spread out in garage so that it's not diluted by rain or blown away by wind. Garage has window in wall and back door but not as much daylight as outdoors. Don't know if this or temperature is relevant.
RJJ
14 Aug 2009
oxygen bleach - you can buy the powder on eBay for pennies. It's Vanish but cheaper.
I think it's what the sailmaker uses if you ask him to wash your sails. It definitely kills the spores...it might not entirely shift the black stains, but it won't actually harm the sail.
Iliade
27 Apr 2005
Shoreham - up the river without a paddle.
www.airworks.co.uk
Not sure if sunlight and temperature have an effect but I'm pretty sure I read somewhere that rain does help once the pm has dried.
Also check the concentration of the active ingredient (BAC) in your pm. It is used as a sanitiser and because of CV-19 became almost impossible to get and then very expensive when it did reappear on the market.
It was as per here. I'm unaware of it changing, but...
jwilson
22 Jul 2006
I have always understood that bleach definitely damages nylon and makes it go yellow, but does not affect polyester/terylene/dacron other than helping get rid of algae green and black mildew staining. The ingredients in Patio Magic also reduce algae staining but rather slower than bleach.
