maby
What has MMSI got to do with AIS? You get an MMSI number with a DSC VHF.
You are quite right, of course!
Taken that the first three numbers are for nation of the number that gives 999,999 numbers available for UK use. It would be interesting to find out the number of MMSI registrations issued.
Linking yoy AIS receiver to a DSC VHF Radio allows you to make a DSC call without reentering the MMSI number
Very few radios have that capability.
All the Standard Horizon GX 2??? do. in fact they display the MMSI in a list in the order of CPA. My GX2000 that does not have an AIS receiver built in displays a list with an external feed so its just a software change foe most Radios that don't
Thanks for clarifying that, I thought we only had one.No, the UK has 4 MIDs - 232, 233, 234, 235 - so already has about 4 million possible MMSIs. If we were to run out, it should be feasible to add another MID, as there are about 20 unallocated European MIDs.
My AIS set needs an MMSI number to be entered before it transmits a signal.What has MMSI got to do with AIS? You get an MMSI number with a DSC VHF.
When I bought the boat a previous owner had entered a Swedish number, a simple figure transposition, and I had to ask the manufacturer how to re-set the MMSI to the UK one.
Sorry, I assumed that everybody knew that an MMSI number is allocated to a vessel. My bad.It requires an MMSI, but I'm pretty sure that is the MMSI of the boat's VHF - I don't think the AIS requires its own MMSI.
True, but my AIS kit is self contained as I have a none compatible VHF radio. I think it is only iCOM that send the sentence and I have a Standard Horizon.In theory with AIS transmitters that accept the NMEA0183 VDO sentence you should be able to send your MMSI within the encapulated message (6-bit encoded accordng to the ITU spec for AIS messages). I've not personally looked into any that work like this, but I presume there are some on the market somewhere.
Is that by choice or local regulation? It seems in the UK you can't do that and need to apply for a new number to be issued. See this YBW archived threadOn issue is the TCU never considered hand held DSC VHF radios. My HH DSC has my ships MMSI programmed.
I think you only had one reply to this question. I have had an AIS receiver for a few years and found it both very useful and also annoying at times when the alarm keeps going off in crowded waters. I ended up with the alarms off most of the time. Anyway, I decided that I would upgrade to a transponder so there was a bit more of a chance of being seen in bad weather. When I was looking just after Christmas the best value for money seemed to be the Digital Yacht AIT 1500 from Cactus at just under £400. I bought it at London Boat Show and got a free antenna. It was straightforward to setup and configure by plugging it in to the USB of a PC. Mine is wired in to my Garmin plotter, but the instructions mention that if using it with a laptop it should be via the nmea cable. I presume you would have to use a serial to USB converter. It seems strange you can't use the same USB cable that you configure it with.OK having read all the reply's I am now looking at getting a transmitter/receiver, however as I have to spend quite a bit of cash on up-grading Shady for the future, costs are paramount on new kit.
An AIS looks to be very expensive and I need it to work with my PC and Navionics charts. So what bit of kit is the best value for money & from whom?
So it seems that transmitter/receivers are still a lot more expensive than receive only
