RobbieW
The following cut and pasted from Wikipedia, so not gospel. However it illustrates the differences between Class A and Class B, also gives a possible explanation for the dissapearance of Class B targets - if all slots were to be busy for long periods, the CSTDMA based Class B transmitter would never find a suitable slot.
That argues for installing a SOTDMA based Class B item, but anyone know whether there is a price penalty for doing so?
Class A
Vessel mounted AIS transceiver (transmit and receive) which operates using self-organised time-division multiple-access (SOTDMA). Targeted at large commercial vessels, SOTDMA requires a transceiver to maintain a constantly updated slot map in its memory such that it has prior knowledge of slots which are available for it to transmit. SOTDMA transceivers will then pre-announce their transmission, effectively reserving their transmit slot. SOTDMA transmissions are therefore prioritised within the AIS system. This is achieved through 2 receivers in continuous operation. Class A's must have an integrated display, transmit at 12 W, interface capability with multiple ship systems, and offer a sophisticated selection of features and functions. Default transmit rate is every few seconds. AIS Class A type compliant devices receive all types of AIS messages.[19]
Class B
Vessel mounted AIS transceiver (transmit and receive) which operates using, either carrier-sense time-division multiple-access (CSTDMA)or SOTDMA; there are now 2 separate IMO specifications for Class B. Aimed at lighter commercial and leisure markets. CSTDMA transceivers listen to the slot map immediately prior to transmmitting and seek a slot where the 'noise' in the slot is the same or similar to back ground noise, thereby indicating that the slot is not being used by another AIS device. Class Bs transmit at 2 W and are not required to have an integrated display: Class Bs can be connected to most display systems which the received messages will be displayed in lists or overlayed on charts. Default transmit rate is normally every 30 seconds, but this can be varied according to vessel speed or instructions from base stations. The Class B type standard requires integrated GPS and certain LED indicators. Class B equipment receives all types of AIS messages.
