DipperToo
Fitted an EasyAIS 2 years ago - very simple and not so expensive. Works really well.
The unit has a multiplexor built-in and I have my fast heading NMEA going into the EasyAIS and the combined output goes to the C80. The C80 as already mentioned needs to be set to the higher speeds. Unfortunately, the C80 NMEA output also has to have the same speed settings as the input. If you use the output for position data for the DSC radio, several Raymarine instruments can output NMEA as can the autopilot.
The speed limitation is also a hassle when trying to transfer waypoints to a handhelp plotter as you have to drop the speed settings first, do the transfer, then set things back to the higher speed.
Hope this helps.
Hope this helps.
